WD 45 locked up
Anonymous-0
Engine runs fine, can shift into and out of all gears---Use the clutch to move and engine stalls out. Lifted rear wheels off the ground and they turn freely. LOST!
What happens when you put it in gear and leave the hand clutch disengaged? That'd narrow it down to before or after the transmission. is the PTO engaged? With both rear wheels up do they turn in opposite directions? Can you try to run it with both wheels up and see if that kills it?
AaronSEIA
Thanks for response Aaron SEIA.
Will try- leave the hand clutch disengaged. Wheels up turn in opp. directions. Will try running w/both wheels up.
Put the tractor in neutral. Then start the engine and let out on the foot clutch. I will bet the tractor MOVES. I think you have a shifter problem that is causing you to have the transmission in two gears at once.
Kent
