d-14 brake job problem
Anonymous-0
I have the final drive assembly off, and I can see the drum and pads are covered with oil. I need to pull the drum and my puller is too small. I have another puller that would work if I could remove the drum and shaft as a unit and use my big gear puller outside of the case. Is there a way to remove the shaft and drum as a unit? How else can I replace the outboard oil seal without taking the shaft out?
I have not done a 14, but I imagine it would be similar to a B or C. I put the final drive in a press and press the axle out of the brake drum similar to how Dick showed someone on a similar post. Dave.
