Gary r. voigt
Hello allis fans...i just bought my first allis "B" i have had a lot of tractors all my life from john deere (as you can tell by my email) to allis wd45"s to farmall...as you know the price of gas is getting high so i wanted a small tractor to mow 1.5 miles of grass road on our property up in northern mn. this one is a 1938 with as woods L59 under it...
tin is 99% and the engine is tight and sounds great...the only problem that i have encountered is when you shift into 1st or second, very fast it gets caught in between gears and you have to pull the cover off and fix...if you shift real slow then it seems to work fine...another member "old" told me it was possibly the fork in the shifting housing...any other ideas what it might be..."old" has been very helpful and has a lot of knowledge on tractors. also i would like to restore this "B" and just would like to know where do i get most of my parts like, tires, seat,
carb kit, muffler, setiment bowl, wire harness, temp gauge, etc.all the items one needs to do a top restoration. i live 30 miles from orange spectacular in hutchinson, mn. so hope to see some of you fellows there. i will post a pic of my allis when i get a chance...
thanks for your help in advance.
Gary
Gary
