having trouble with the clutch on my C. It wouldn't shift so upon futher investigation, looking though the access hole on the bottom of the bell housing, I saw broken parts.
We split the tractor to find that one of the fingers on the pressure plate had broken off and was shot.
So we Picked up a new disk, pressure plate and throwout bearing. Everything went back together without a hitch. Then once we started it and tried to engage the clutch, Bang, one of the fingers from the new pressure plate goes shooting out the access hole in the bottom of the bell housing!!!!
After splitting the tractor again, I appears that the arm the the clutch pedal rod screws into on the throwout bearing assembly had made contact with the pressure plate and busted off one of the fingers!!!
Has anyone experienced this before? We are puzzled and out $130 for the new, now broken pressure plate.
Thanks
Thanks
