Mitch H
New User
I have a 41 C and am looking to put a drawbar on it but am having trouble finding one. Any thoughts? It has a Woods belly mower on it. Are the two compatable?
You will probably get a reply from someone on here with a drawbar.
You can register your location, and it will show up in modern view. That is almost always important- as there is an AC graveyard near here, but where are you?
Yes the drawbar and Woods mower mount are compatible. The manuals for Woods are available on line. The pictures in them are worth a "thousand" words. Seems like there might be a picture showing the drawbar and mower mount.
I have not had a C with a Woods mower under it but do under one of my B's with the drawbar on. Should work the same with the C.
I saw a C drawbar on ebay a coupla days ago. you might check to see how close it would be to you.
I most likely have a draw bar for one but may not have the bolt/pin plates that are used to hold it on. Of course where you are at can make a big difference since it would not be an easy to ship part because of its odd shape and size
I have a woods mower and C drawbar both on My C at the same time. I also have a extra drawbar. Don"t Know if I can find the Pins. I made a set in about 30 minutes. depending on where you are shipping is usually the deciding factor on where you buy one.
