Farmall M Beginner
Sorry to bother every one again.
I have a WD that was running great one day and then it wouldn't start the next, here is what I have done so far.
I have put in NEW points and condenser, then took the mag to a shop and it tested out good. I put in NEW spark plugs and I replaced the carbine wires with copper.
I have put in a NEW carburetor rebuild kit.
I have timed the tractor over 30+ times and it still acts like the timing is a little off?
The tractor starts and runs but will not throttle up, I have unhooked the throttle linkage and tried adjusting the throttle on the carb and it still would not throttle up.
When the tractor is running there is NOT any smoke out the exhaust?
If the tractor is running a little out of time how can I change it? I have rotated the mag while the tractor is running and it starts to run better then I am out of adjustment.
I set the timing to all the marks while the #1 cylinder is at top dead center.
If any one has any ideas PLEASE let me know.
Thanks for any info
Thanks for any info
