WC Spindle removal
LWW
How do you go about removing the spindles from the bolster on a narrow front WC? I don't think they're welded in, and suspect they can be replaced, but don't know how they are removed. Any and all help will be appreciated, thank you.
I don"t think they were welded in.
There should be a pin holding the spindles in.
If yours are welded I would think someone did that. Not the factory.
.see if this helps
<a href="http://s33.photobucket.com/albums/d84/Joecdeere/tech%20pic/?action=view&amp;current=wcspend.jpg" target="_blank">
wcspend.jpg" border="0" alt="Photobucket
</a>
Like the other Jim says- they are pinned. Clean it up well after removing the hubs, wire brush the paint, and you should find them. Often flush with the casting, so you need to look carefully for the telltale circle. I don"t know if they are tapered pins, but just in case, I would not pound on any end sticking out.
