Farmall M Beginner
I have a A-C WD and I went out to start it and it would fire but wouldn't run, so I pulled it with another tractor and when I was pulling it, it would run really rough and it backfired so hard it blow off the muffler cap.
I took apart the carb and every thing was clean, so I then turned to the magneto, like an idiot I took off the mag cap before I noticed the spark plug wires where bad, so I replaced the wires, and re timed the mag and now it doesn't have any spark at all?
Would any on know what is wrong? If the timing was off I should at least have spark?.
Also what is the #1 cylinder? I was thinking it was the one closet to the operator?
I haven't check the points or condenser yet.
I'm not very good with mags, I would like to learn some about them but I don't know any one that can work on them.
Thanks for any info
Thanks for any info
