I've got 3 allis C's in my garage one is on a skid broken down for parts----BOTH drawbar pins firmly rusted in place even though they were seriously treated with penetrating oil and heat. One was even drilled out for a threaded rod and slam hammer.
Today I decided to check out and adjust the axle bearings on my mowing C. BAD IDEA, needed to remove the belly mower mount to access caps. Of the four bolts two are broken off flush, one I broke and one was previously broken. Lucky for me it only had one drawbar pin and yes it's FIRMLY RUSTED IN PLACE. I've been dosing the bolts and pin with PB and ATF for a few months and it didn't seem to help. I'm certain the broken bolts are capable of destroying an easy out.
The 3rd C needs some bearing work in the rear end and trans. I've been dosing the pins and bolts for a good 6 months. This tractor might be a little better since it appears to have spent more time in out of the weather.
Sometimes these old tractors just ain't much fun.
