180 vs 185 Alternator Question
charles todd
Will an alternator and tachometer drive from a 185 work on a 180? Next question is the tachometer and cable different between the 180 and 185. If they are different are the ratios and rotation the same? Could one service the other and read correct. I have read the ratio is 1 : 1.48? I know ya'll have some answers on this one!
Thanks,
CT
x2 on the agcopartsbooks. I was glad when they added the log in as a guest button. When customers come in for tractor parts at my auto parts job, I like to have the OE numbers when the after market books are sketchy or do not show a thing. We also have an AI and Tisco account so often an interchange through either one will save the day and the customer money (or driving 70 miles for an AGCO dealer). Sometimes the ai and tisco lookup or paper catalogs don't show the part by application but the interchange comes out with the right part. At least with the OE number there's some assurance the interchange should be correct rather than just guessing.
Try some of the other online tractor stores too. I think yt is lacking on the tach drive parts but there are some other vendors online. So if YT fails, try steiners for example.
karl f
Thanks guys. I have a parts book for the 180 and I had looked at ACCO online. I have also spent several evenings cross referencing after market parts as well as networking with some salvage yards. What i have noticed is some parts for 180's do not exist any more. Maybe I am spoiled to the after market world of IH.
I know the tachometer itself looks the same but different numbers between 180 and 185, but the after market says it replaces both. The alternator and drive part numbers I believe were the same. What has me concerned is a post on the "Unofficial Allis Chalmers Forum" discussing the after market tach drive.
Some guys took their tach drives apart to count teeth and measured pulleys. OEM is quote, "The crank pulley diameter is 7-5/16, 12/45 tooth count in the gear box and like already mentioned the alternator pulley is 3-3/8." Also they say the after market drives are 14/43 teeth which causes the tach to run about 500 RPM high. So to use an after market drive would need a 4-1/8" pulley to offset the ratio change.
This is why I am confused... Any one buy an after market drive or tach? If so did it work correctly?
I appreciate the help Orange Friends,
CT
I have no experience with the aftermarket stuff.
I'm going to guess the difference in alt. from 180 to 185 you found is only the amp. rating.
I was surprised just a couple years ago helping a friend on his MF 65, the tach. drive parts on his gen. looked just like the AC stuff used on the alt. However I didn't do any tooth count/comparison. We got everything we needed then from AGCO.
