7080 counterbalanced crankshaft
ac literature states that 7080 motor crankshaft is counterbalanced. when i look at service manual and parts manual i see no mention of this. i was expecting a gear running against crank. what does ac counterbalance mean ? got pics on agcoparts book
In-line sixes don't need a balance shaft/gear setup.
The weights in question are the weights opposite each crank throw.
the counter balance on the allis 7080 is on the lower crankshaft pulley. you do have to inspect them once a year to make sure they are not coming apart. this can be seen by look at the pulley and if there is a rubber ring coming out the front of the pulley. it is starting to fail. if not fixed you will notice a vibration coming from the front of the engine. this some times has been linked to the crankshaft breaking. it is a good idea to check this out.
Let's call that a "torsional damper" or "vibration damper" rather than a "counter balance", which is it NOT!
