another wd question (pic)
sHan,TN
hi guys, kinda pushing it a bit here BUT what do yall think about this wd? anybody see anything bad? i see the right rear tire has some bad cracks, i "hopefully" mad the picture large enough to get a good look... any idea on the price? they have the fenders but not on it, thanks.....
-- Things I do not like about it. Drawbar is missing. Missing the rear platform leaving the PTO exposed. If you put the fender on it put shorter pins in the lift arms to keep from tearing up fenders. The air cleaner seems to be missing. Need a look at the other side to tell for sure. The tin work looks pretty good. Might be a few things that would make a purist start preaching but nothing to keep it from working. My offer would be 5-6 hundred
I'm with Sid no draw bar and no platform make it so that it will cost you around $500 to add them and you need them. As for the tires I have seen much worse last for decades. Maybe a $1500 tractor give or take a few $$
That rope on on the hand clutch could just keep it in reach for the driver, but the foot clutch also is locked in or broke. Must be a custom battery box and missing dash assembly and lights. Dan
I agree with Sid, I wouldn't go over $500 Think twice becuz when your finished you will be putting $2000. into it, so with all that money you could get something a lot better, don't waste your money and be sorry. good luck
depends on what your gonna use it for. if you need a tractor for just 3pt stuff, it would be fine as it is. if you need drawbar also keep looking unless you really beef up that center section to withstand the leverage that it will take when using the drawbar. the rear platform aint that big a deal, i havent had mine on either of my WD's for years. one is no prob since the pto dont work, but the other i have no issues with. check your clutches, that hand clutch can be a real mother if it aint working correctly. good stout and handy tractor, biggest downfall is the rear tire size.
Big questions for me would be: How does it run? Does it smoke? How is the transmission? Then finally how bad do you want it and what are you going to do with it.
thanks Guys... i just want it to poke around the property here, mow some grass with a 5'finnish mower and pull a 1 bottom 16" plow a couple times a year. other than that just tinker around the place,
thanks again
Oil filter has not been changed since Before the tractor was painted.(Pink??)..
That type add-on 3-point takes away the traction booster feature and clutch "kick-out" if you hit a rock while plowing..
Be sure to check to see if the PTO actually does work and does not have broken gears..
Ron..
Oh June the time of the year the honey do list gets very vewry long and you still have no time to do any thing LOL
Lot'sa stuff either missing or wrong. Wrong muffler, headlights missing, pto guard missing, rear tires mismatched. As said by others, you will have more invested than it's worth. Painted oil filter says engine has not been properly maintained.....other things? Don't walk away..........run!.
