charles todd
I managed to load the tractor when I bought it before fully understanding the PD system. I read the operator manual and the archives, now I think I understand the basics.
I understand the PD to be a hydraulic wet clutch pack. 3 clutches high, 4 clutches high. I understand when they are cold they tend to creep a bit (it does). I tried all gears high and low and it will pull through the brakes. I did notice that at low engine RPM's it tends to slip a little when taking off from a dead stop, especially in 7th and 8th. But if I rev the motor it pulls hard, quick. The PD when going from high to low will "engine brake" and it holds speed going down hill. I did shift from low to high at low engine RPM in 3rd and it slipped going across a creek crossing.
My question is why at low RPM does it seem to slip in the higher gears taking off and at higher RPM's its a rocket. Is this a hydraulic pump/valve pressure issue at low RPM's? Is this normal? Do they not like to be run at low idle? Is the PD going to require "shimming" in the future?
I do have a new filters in the mail. The fluids look good, but will all be changed within a week or so. Could this be some of my issues?
Thanks!
CT
Thanks!
CT
