WD45 Wheel Weight ?'s
I have a set of wheel weights for a WD45 front and rear.
I was wondering how much do the back ones weigh and front ones weigh?
Also can I bolt the front weights to the inside of the wheel so they are not such an eye sore? Thanks.
I believe the rear ones are about 125#.
I have no experience with the front ones, however I believe the inside ones were cast in two pieces, so they could be installed without removing the rim.
Also -is the center hole in the front weight even big enough to go over the hub, even if it would fit the inside of the rim?
The hole looks like it is big enough to go over the hub but I don't know for sure for. I haven't messed with trying to do it since its so heavy till I know it will work this way.
It took getting near my to C to jog my memory! It has inside wheel weights all the way around. The front ones are one piece, and are absolutely flat on the exposed side. I measured the rims and it appears the same wheel center was used on 15" and 16", so I would assume the bolt mounting hole dimensions would be the same.
Seems like outside weights were very much doughnut/rounded shaped, with a valve stem notch.
I tried putting mine on the inside. Not enough clearance they were rubbing on the spindle. Did you add a spacer to your wheel?
