clip or no clip for float needle?
mdm1
Location
Onalaska,WI
My parts should be here soon and I am going to put a new float needle and seat. I read before not to use the clip on the needle. Opinions. It's wd-45 the one that stalls under load. Mike
The clip is there for a good reason. Most new needles are the rubber tipped type that can/will stick in the seat so the clip is there to keep that from being a problem. Also if you new needle is a rubber tipped one you need to set it so it will seal like it should. To set it you drop it in the seat and tap on it with a screw driver handle etc. When you pull it back out you should see a ring on the tip and that is what is called a set needle
If I remember right your float has aa dent in it right?? If so that can cause you funny problem with how it does or does not float as it should
