C Allis miss' after an hour
Shawn MN
I have a C Allis with a mower deck on it. After and hour or hour and a half it starts missing and running on 3 cylinders. Why does this happen? Coil?
It it always the same cylinder or does it sort of move around?? If it is always the same cylinder I would say you have a valve that might be set a tad tight or a valve that starts sticking. If it moves around I would say you have a coil going bad and a coil going bad will make one miss and spit and sputter
Must be a valve. It's the same cylnder. And yes it wil restart. It just loses power and then dies. Thanx guys!
