dantheapplered
New User
I am having a problem with my hand clutch on my ca Allis Chalmer.
When I got the tractor the whole clutch was froze up. We sent clutch off to be repadded because we couldn't find one. We had metal plate turned down to match it. After put back together-It will run until it is put under a load then it starts slipping and smoking, then when it takes a hold it pulls good. When you let it set for a few days you have to start all over. I have adjusted the adjustment wheel back and forth, I have no Ideal what is causing it to slip. Open for any suggestions. There is a little grease on the brake housing above it but doesn't look like any on clutch. Can this clutch be put in backwards? Thanks
[/list]
[/list]
