Company Logo Shop Now
D-17 starter
Keith Molden
01-10-2011 07:13:19
My D-17 diesel has been converted to a 6 cyl. gas engine, but it appears they have used the diesel starter. Question is, is there a difference in the rps of the 2 starters? The starter that's on it doesn't seem to want to crank it fast enough to start it. Time is set correctly & if you pull it to start it, the rear wheels won't even make a full revolution before it starts. I've had the starter checked & they say it's good. Any thoughts? Keith
Tramway Guy
01-10-2011 09:43:37
 Re: D-17 starter in reply to Keith Molden, 01-10-2011 07:13:19
A lot of starter circuits have 'resistor bypass' terminals where the full voltage goes to the coil only when starting. When running, voltage goes through a ballast resistor.
That being said, you should check all your battery connections and starter / ground connections.
Wisconsin Cowman
01-10-2011 07:28:15
Battery and cables are in good shape?
paulinkansas
01-10-2011 07:26:44
I had a problem with the starter on my D17 gas. It didn't seem to have enough power to crank it over. The problem was a bad oonnection between the copper battery cable and the lead terminal that clamps to the battery post. The cable clamped to the terminal. I bought a new cable that was one complete unit (you couldn't unscrew it).
Keith Molden
01-11-2011 12:03:44
 Re: D-17 starter in reply to paulinkansas, 01-10-2011 07:26:44
Thanks for the info guys, I'll get in the shop this week end and check the connections again. Keith
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: I have A narrow front end from 65 Massey and also a front guard for a 65 Massey call or e-mail for price. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
