Company Logo (800) 853-2651 Shop Now
WD pto shear pin
Tony S.
01-08-2011 19:41:32
What are you guys using for shear pins in the pto shaft on a WD? Don't seem to have room for a nut on a 1/2" bolt on mine.
Ray Burd
01-13-2011 04:39:55
 Re: WD pto shear pin in reply to Tony S., 01-08-2011 19:41:32
I learned the hard way not to use a bolt as heavy as a Grade 5 when I bottomed out a 5-foot rotary mower on a stump -- exploded the PTO box just about off the transmission. I can't find Grade 3 half-inch bolts through any of my local sources, so I use Grade 2. I buy in bulk because, with the same hole warbling mentioned by someone else, I replace a couple of bolts each summer. But, replacing those bolts is a lot less expensive than replacing PTO boxes.
steven wilkowske
01-10-2011 21:20:11
We always used grade 5 bolts, grade 3 may be softer but don't shear correctly on impact.
BG-KS
01-09-2011 16:00:28
I use a grade5 1/2 inch bolt with red locktite.
The hole in the pto shaft is wallowed out and chews the bolt in half given time. I have since found a newer pto drive but haven't got it on yet.
Tony S.
01-09-2011 13:58:48
Thanks. I actually was thinking of using some mild steel 1/2" rod and drilling the ends for wire to tie it in. Or maybe hot riveting the ends. I don't expect to do any heavy pto work, maybe a sprayer pump.
Bill(Wis)
01-08-2011 21:41:03
I used shoulder bolts from a harware store that has an extensive stock of bolts. He said it was actually an axle bolt for a toy wagon. (Like a radio flyer).
big jt
01-08-2011 21:40:00
It is kinda a special bolt. Half inch bolt with 3/8 threaded end. Lets you clamp it in tight to the shaft without trying to clamp down on the shaft itself.
AC and lots of aftermarket places handle this bolt.
jt
old
01-08-2011 20:39:05
Been a long time since I replaced one but if I remember right it is a 1/2 inch bolt and a nut but as I said been a long time since I had to replace one
BushogPapa
01-09-2011 07:58:38
 Re: WD pto shear pin in reply to old, 01-08-2011 20:39:05
Even with an Original shear-bolt, I drill both ends, so I can safety-wire them in. If the bolt does shear, an end is not going to slip out and jamb against the case.. Never thought about a Lawn Mower spindle bolt...!! Good idea..!
Ron.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c ... [Read Article]
Latest Ad: 4386 or 4586 IH [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
