remove rear axle off of a 185
davidmealy
New User
Could you please tell me how to remove a rear axle off of a 185. I have removed the snap ring and cap screw off of the rear axle but still cannot get it to pull out. Any help would be appreciated.
Thanks,
David Mealy
[email protected]
if it is like a 190xt, first of all you need a shop manual. you have to torque bolt and preload bearings. anyhow
this is how you do it (if it's like a 190xt)
1. take the rear rocker arm housing off the tractor. (first drain fluids in transmission and final drives)
2. remove the metsl half moon do-hickey from both sides (they cover the end of the axles)
3. remove bolt and washer from axle you want to take out.
4. on the outside end of the axle remove the 4 bolts
5. go back into the inside of the tractor with a jack of some sort and start jacking the axle out of the axle housing.
I don't know what the torques are for the 185 or the preload of the bearing.
(quoted from post at 18:17:45 12/04/10) if it is like a 190xt, first of all you need a shop manual. you have to torque bolt and preload bearings. anyhow
They aren't the same. Thanks anyway.
The manual says to support the bull bear and bump the axle out after removing the cap screw, snap ring, pinned washer, lockwasher and shims.
Sounds simple doesn't it?. It's never that easy.
Remove the cap screws , cover etc, wiggle, jiggle, and pull the axle out , may have to use a bar to bump it ; THEY ARE NOT THE SAME AS AN XT ; just use the same shims etc in the same spots should be good to go
It is not like a 190XT, it has a different final drive than the 190 and above. I have a manuel at home and if I remember I will look it up for the 185.
