larry Mi
Fireing order 1342 ? Where do I find the timing marks flywheel or crank pully? Thanks.
Iam working on my boses tractor it has all wires riped off it. I may have more questions later.
Larry
You may find two marks on the flywheel.
DC for top dead center and F or fire.
Set it up at top dead center not running and then if you use a light set it to the fire mark in the center of the window.
1,3,4,2 is the firing order for the Farmall tractors and does not work well on the Allis tractor which are 1,2,4,3 for the firing order. Oh by the way if you try to use the 1,2,4,3 firing order on a Farmall that does not work well either I know because I had a Farmall B engine that way it it just didn't seem to run well for some odd reason LOL
Is # 1 still up frount or did they move that too? Iam a Moline collector much easyer to work on.
Jeff Z. First thank you for your help. Where is there an inspection hole to see the timing marks on the fly wheel?
Yep #1 still up close to the radiator on almost any of them. Now as for the MMs being easier to work on I'm not so sure about that one since I to have had or have them also. Have an RTU right now but can not seem to find a set of cylinders for it with out costing an arm and leg
Only one I ever heard of with #1 at the rear was a Deutz. But then, I don"t hear everything!
