Company Logo Shop Now
unstyled WC bellhousing and transmission question
redd720
11-02-2010 17:27:38
I am working on 1937 WC it has bad transmission and cracked bellhousing. i got another transmission and bellhousing. the motor is not on tractor.
Will it work if i pull front axle and support out from the main frame and put another transmission and bellhousing in it? I don't want pull rear end out because i am afraid i might break the bolt on main frame and rear end. It look harder than front. will WD45 front support and axle fits on Unstyled WC?
Thanks
Tracy
wilson
11-03-2010 07:13:50
 Re: unstyled WC bellhousing and transmission question in reply to redd720, 11-02-2010 17:27:38
Heat the stuck bolt head red Let cool several hours when relative cool spray with ps blaster wait till tomorrow to loosen
JMS/.MN
11-02-2010 21:08:46
Since the engine is already out, it is simplest to just switch the bell housing and transmission, out the front. Loosen up the side frame bolts, spread the C-channels a bit, and switch castings. Fronts interchange.
chalmersbob(pa)
11-02-2010 19:01:13
Just remove the rear bolts 1 at a time and install a long threaded rod in each position, and slide the rear away from the frames. Bob
redd720
11-02-2010 19:42:18
 Re: unstyled WC bellhousing and transmission question in reply to chalmersbob(pa), 11-02-2010 19:01:13
I hope i won't break the bolt. i tried loosen up today it still so tight. i am afraid if i do hard on it it might break the bolt. but i got all bolt loose in front axle and support. i thought it would be easier. Do you think so?
Thanks
JMS/.MN
11-03-2010 14:59:16
 Re: unstyled WC bellhousing and transmission question in reply to redd720, 11-02-2010 19:42:18
After heating red hot, apply candle wax as it cools. Melts into the threads as it cools. Giver it time, few hours or so.
MIKE BOCK
11-02-2010 17:33:47
every thing will bolt right togetherthe only bolts that break easy are the front pedistal bolts to side frame
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: I have A narrow front end from 65 Massey and also a front guard for a 65 Massey call or e-mail for price. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
