wd45 axle removel
I went to a pull today and heard a crack. Tractor won't move at all. It was clunking on the right side just before I pulled. I'm thinking the small gear at the top of the final drive sheared of from the axle. Just wondering how much of a job it is getting the axle out. Thanks
Take the right wheel off. At the top shaft there is a cover with four bolts. Remove that and if you can remove the bearing, you may be able to see the small gear behind it. Pull the bottom cover to turn and inspect the large gear. Pulling entire final is no big deal- remove bolts on either end of sleeve bolted to the differential housing.
You have to remove the pin for the brake shoes and remove the shoes too so the final drive can come off. This pin is a bear to get out if it's never been out before.
