leak water pump on a B
eegj1
New User
Water is leaking around the shaft on the front. Is there an o ring to replace?
Thanks in advance.
That price is fair for the one with the bypass hole.
If you don't need the bypass you should be albe to find one for $100.00.
Try Tony"s Tractor
If there is a plug in the side of the pump you have the one with the bypass that is not needed.
Go to Tony"s Tractors site {Google It} and look at the pumps under radiators and cooling.
i think either pump should be o.k. for the B or C. I believe the smaller D series used the same size pump and the bypass was needed on them.
