can't get magnito to reach gear
chad herrick
New User
I have a 1941 ac modle b and I can't get the maginto to reach the gear that turns it. The ears on it seem to be about 5/8 of an inch short from sliding into the slot. I have called around and I seem to have the right mag. Any and all ideas will be a big help. Thanks
has your governor gear in moved foward? are all parts of governor properly installed as to not let governor gear move foward? just my thoughts. good luck, d.coleman
you can scale this drawing of the mag and see if it is close. you should have a FMX or FMJ mag on your tractor ??? Most would fit, i would guess that the mag distance is a standard on MOST mags. I dont have the depth of the gear inside the motor housing. Was this running or did you take apart and repair ?????
http://www.oldengine.org/members/diesel/FairbanksMag/Mag30.htm
Untitled URL Link
If you have that wide of distance the governor shaft would have pushed out the front of the governor cover.
Click on the link and then click on the pictures to move forward to see what the problem (could)be.
Governor Pix
sure you didn't forget the bakelite connector with notches one side and notches 90 degrees on other side
