allis chalmers wc with wd-45 crank
LMC
New User
I was wondering what all I needed to put a wd-45 crank in a styled wc, dose it just drop in with same pistons and rods or do I need wd-45 pistons and rods, and would the compression be to high if I used the flat top pistons for in wc. And will the crank pulley from the wc crank fit the wd-45 crank. And do you know what horse power it would be? Thanks.
the rods are the same the piston height is whats different to make up the 1/2 inch stroke. If your doing a puller use the wc pistons . If planning to do field work you will need a wd 45 d17 170 or 175 piston.
