Ted J
Hi, I am trying to find the J Bolts that connect the manure bucket frame to the WD45 tractor. They are 5/8"x3 1/2". I need 6 of them, as I have 2 that came with the setup. I would also like to know how the hydraulics hook up to the tractor. It came with no hoses or anything, just the trip bucket, frame and some bolts. Thanks, Ted
If you don"t have an oxy torch, any welding shop can make some J-bolts for you. Re hyd: you need a single hose from the unused port of the hyd valve- where two hoses attach, going to the lift arm cyl- there is a third port- take out the plug and attach your hose there. Use a quick-coupler for convenience, tee to both cyl hoses on the loader. You have a trip bucket, just need one-way hyd to lift the loader, gravity down.
Hi All, Anyone who is looking for the bolts, I found them at: http://www.fastener-warehouse.com
They are listed as Hook Bolts. They are 5/8"x4" and were $1.50 ea. GREAT PRICE!!
