WD45 frame rail removal
RFM
Restoring a WD45 & would like to do a complete job & paint inside of frame rails.
Is there a safe way to remove them without the tractor twisting or falling apart?
Thanks for any info.
I have been told that it is possible to securely block the front end and the clutch housing and unbolt and remove, paint and reinstall one rail at a time. The tractor can't be moved or hold up its own weight, but it saves taking more things apart. I have never done this myself, but it seems logical.
Zach
I just did a WC, removed the motor, then one frame rail, cleaned, repainted, reinstalled, then did the other side. Left the wheels and tires on for stability.
I did mine and took both frame rails off, there is no reason you couldn't do one at a time. I would still support the center at the bellhousing.
The WD45 is built much stronger than the unstyled WC so I agree, both rails could be removed as long as you support it as described. I would add, before you do, take lots of pictures unless you have another one close to look at in order to get everything back together correctly the first time.
