wd 45 hydralic leak
i have 57 wd 45. hydralic oil is leaking out of the pan under clutch housing i removed pan seems to be coming from seal of shaft going into hydralic housing right above where you can grease clutch mechanism. how the heck do i get to this i"m sure it aint a walk in the park. any info please
That seal usually gets damaged by letting the hydraulic reservoir run too low for an extended time..
The seal runs dry and then it's a bad seal..
My guess is that you will lift the engine out..
Not a bad job..just take the radiator off, unbolt the engine and lift it out...(no power steering, right??)..
There may be others who have another way, but I would expect anything else to involve "Spitting the tractor..
Ron..
