M Stanley
New User
I am replacing my seat assembly and the rubber grommets that go on the main bolt were the seat bar mounts to the brake cap are worn out. Does anyone know if replacements are available anywhere. I am most likely going to need the bolt as well. It did not fair well during removal either. If anyone could help I would be grateful.
You didn"t spec the model, but sounds like a WD or WD45- they use the same....check with AGCO, Steiner or others. Same part is used on some Farmall"s, like H, M. Very common part.
Sorry, missed that one big time. I have a 56 WD45. I rebuilt the engine and several other areas of the tractor about three years ago and I forgot who all of the part suppliers were. I remember AGCO now that you mentioned it. Thanks, I will try them as well as any other suggestions.
