allis C rod and main bearing shims.
are the shims for rod and main bearing caps supplied in bearing or o/h kits, or do they have to be obtained from a differant source? if a differant source, where? has anyone made them from regular shim stock? the ones in my engine were not reusable or at i wouldn't choose to reuse them. thanks, d.coleman
you make your own, or buy from AGCO... not in the kits. get a small sheet of .002 and cut them with sissors.
thanks for response. have plenty of peel shims at work. will get to work on a set as soon as i go back to work next week. d.coleman
Use aluminum flashing when thicker ones are needed.
Still can be cut with the wife's scissors when she is not around.
had a n old allis dealer tellme to use a beer can for shim material---- i used a pepsi can on an allis b...it worked great for many years --i think about the next guy to open up that engine!!! ....???????????
