1955 w/d 45 Frozen
raphial
New User
on 08/14/10 we put in 50/50 acetone & atf in cyl. we took value cover off & vacume all the rust out & off. the values appear to be loose. we put atf on values. it will rock a little.. can not get hand crank to go @ all. how long should we wait??? no need to rush would rather try what ever than spend big bucks..first allis not running yet.
thanks guys for your help !!!!!
Trying to spin over a locked up engine with a hand crank is like trying to push a D8 cat with a lawn mower it isn't going to happen. That said what I do and I do it all the time is set a 12 volt battery in and use short fast taps of the starter every once in a while say every other day. Don't hold the button just hit and release and do that say 5 times a day till it moves or if not may have to open it up
