Will Herring
Okay, so I had some time to tinker with my WD again this morning. So I pulled the fuel line from the carb, had good flow of gas there. Pulled the main jet, and it just had some yellowish crap on it, but didn't see any sedimentation... So I pulled the drain plug off the carb, hosed the inlet and bowl and main jet out with carb cleaner, let it dry for about an hour (there was a bit of sediment on the bowl plug itself, but the only thing that came out from flushing it was this brown varnish looking stuff, really).
Anyway, so I put the fuel line back on, put the drain plug back in, and decided to fire it up... Or at least, attempt to.
I choked it 3 times, pulled the starter, it fired up and died. Rinse and repeat this step a dozen or so times.
Finally, I decided the heck with it, and pulled the choke and the starter at the same time. It ran for about 10 seconds this time, then quit.
So, lastly, I pulled the starter and the choke, and when it started this time - I just held the choke open, and the thing kept running! When I closed the choke, it died in about 3-5 seconds.
Again, I started it with the choke open, held the choke open, threw it in gear, and drove it up from the pasture (where it had stopped on me) to some shade trees about 100 feet away, so I would have some comfort to work in (it's been 95+ here lately). I throttled it up with the choke open, and whereas it usually sputters and coughs, it revved up no questions asked. Wasn't even running rough or blowing black or white smoke; just chugging along.
So I parked it, played with the choke some (got a bit of white smoke depending on how much the choke was open compared to how much I throttled up the engine), so I finally just shut the choke off, and it died.
So, this is where I am at now. Confused. Should I check my air filter? Do I maybe have something mis-set, still plugged up (again, I didn't really clean the carb out), or possibly broken in the carb itself? It seems like it gets gas, but not enough air. Or the mixture is just wrong. I'm pretty sure I don't have "bad gas", as it were.
The tractor wasn't even running rough when I had the choke held wide open (it wasn't 100% smooth, but it was good for being a cold engine on a hot day, IMO). Running it with the choke open all the time is not an option (it's probably dangerous or bad for the engine, but I do not know). But I've got it where I can get to it more easily now, so any input you can give me would be greatly appreciated. You guys haven't ever let me down!
