wd-45 ,1955., 217555 with mounted 3 bottom
raphial
New User
i bought it & pull it home yesterday about 5 miles she is frozen per my shade tree wrench man. not sure when last run??? i want to put some oil that we have and use to lozen bolts in each cyl. the oil is better than wd-40. this is my first allis.any input will help.
thanks
south central wi.
Oil by itself is not any better than WD40. Use straight ATF or 50/50 mix of ATF and acetone. Suction any water out first, otherwise the mix floats on top.
If it doesn't come loose, you still can put in an "Engine Kit"..that comes with new sleeves, pistons and rings...pretty reasonable, too..
Ron..
