Allis Front Suspension Bushing??
Anonymous-0
Hello All, my 39 B needs a new bushing where the front axle support rods connect together at the back and mount inside the boss at the bottom of the trans right below the clutch. I got one from Sandy Lake, but it seems too big for the hole. Do I try to draw it in with the nut? I REALLY dont want to force anything with the trans case being cast iron. Thanks for any help.
try puting bushing in freezer for a day, warm mount with a torch have a bolt the size of bushing with a washer and nut. while all parts are hot and cold use bolt and nut to act as a press and pull bushing into mount. hope this makes sence. good luck, d.coleman
Well after measuring with a dial caliper, there is no way the bushing is going to fit, must be for a different year. Its the second one Ive bought for it, and both bushings were the same size and no-goes for my tractor. I remember there WAS a very wore paper thin-in-spots bushing I removed from it a few years back. But cant seem to find an appropriate replacement.
what about having one machined or take measurments to a bearing house or NAPA to see if the three dementions(OD, ID, LENGTH)can be matched. if all else fails, what about a brake hone to enlarge the bellhousing hole?(as a last resort only). good luck, d.coleman
