Company Logo Shop Now
CA cutout sticking closed
Rob Sponenberg
07-17-2010 18:44:59
Replaced the cutout on the generator today and now it stickes closed.. Also seems to be charging very high 20amps all the time with the switch in the middle or all the way out!!!
HELP!!!!!
J. Schwiebert
07-17-2010 19:11:12
 Re: CA cutout sticking closed in reply to Rob Sponenberg, 07-17-2010 18:44:59
Too late now but a simple diode is much better than a new cut-out. No moving parts. The field circuit is grounded in the light switch. Is it going to ground some other place? Also what is the position of the third brush and do you have a good Voltmer you can use to check the generator voltage with?
Rob Sponenberg
07-17-2010 19:45:17
 Re: CA cutout sticking closed in reply to J. Schwiebert, 07-17-2010 19:11:12
Need to check voltage tomorrow also will check the 3rd brush,didn't even know it was ajustable untill I read some old posts on here. Needle on the amp meter goes to 20amps at anything above idle and stays there at idle it bounces around very eratic,may even read a discharge????When I shut the switch off it may read 0 or it may read a slight discharge??? Then when I turn the key off it will read 20amps discharge,contacts stuck at cutout which is brand new???? DOESN'T do it all the time but DOES it enough!!!
Rob Sponenberg
07-18-2010 18:08:56
 Re: CA cutout sticking closed in reply to Rob Sponenberg, 07-17-2010 19:45:17
OK,did a little checking with a voltmeter today,I have 6.50 volts on BOTH generator posts with the ingintion switch off and the light switch off???
With the switches off all I have to do is push the contact together on the cutout and they stick instant discharge!!!!
Larry from MD
07-20-2010 09:21:24
 Re: CA cutout sticking closed in reply to Rob Sponenberg, 07-18-2010 18:08:56
Short in generator.
Rob Sponenberg
07-21-2010 17:02:23
 Re: CA cutout sticking closed in reply to Larry from MD, 07-20-2010 09:21:24
Still charging good this is what I dont get?????you would think if its shorted it wouldn't charge???
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
Latest Ad: 3 point drag arm for 420 HD crawler right side [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
