185 Allis Priming or bleeding injectors?
How do I prime or bleed all the injectors on my 185.
Just put in a new fuel tank and filter & I am not sure if they are all primed, she runs just a little rough.
should I hand pump them or crack the lines while running?
Thank You Jeff.
When I took the tank off of mine to clean it all I did was crack the bleeder screw on the injector pump to get it running. After I shut it off it wouldn't start so I cracked the number one injector line at the injector to get the air out and it's ran fine every since. Hope that works.
