Kevin Moschenrose
Hi All! To start I am a Minn. Mo. man and need to know a little information on this C Allis. I am helping a friend work on his grandpa's old tractor in my shop and the starter bendix is grinding from time to time on the ring gear. The starter has been rebuilt on it but the teeth on the ring gear are not in the greatest shape. I know that when tractors are shut off the engine always stops in one of two places and that is where the ring gear is worn. What I want to know is can I split the tractor and turn the flywheel one bolt hole or not? Or does the flywheel only bolt up one way do to the timing marks? I know on my minnies that I can can do this when needed but I didn't want to split this first to find out it won't work on this tractor.
