Joe B
I just replaced the rear main seal and pan gasket on my D17 and still have a oil leak coming from the clutch housing.Any idea what else it could be?Thanks
I have had good luck with this on rear main seals and transmission seals in transmission that use motor oil.
Took around 3 weeks to work.
Were in NY are you?
I'm outside of Albany.
Sealer
I don"t know what material the seal you have is made of so I don"t know if the sealer will work with it.
Jeff this engine uses a felt seal-do you think the sealer will work or is it just for rubber seals?I am just south of Albany
