D17 weak hydraulics
Doug Reser
New User
I have a 1958 d17 series 1 that will only lift about 700 lbswith the rear 3 point. It was leaking hydro fluid into the rear end so I had it split and the line going from the pump to the cylinder was bad, had it replaced and the new seals in the cylinder put in. Did not increase lift power so I had the pump removed and it had a broken roller. Sent pump off and got it rebuilt and put back in. Got the tractor back today and it will still only lift about 700 lbs. Anyone have any suggestions on what else I do.
