The four locking bolts on the rim are stuck. Tried heating up the bolt with the torch and melting wax into it, twice. Then heated the block piece and not the bolt. PB blaster over several days. Still have the tubes in them so they can't get too hot.
1200 ft # impact gun didn't budge any of them. Used a 5 foot bar and a long breaker bar and it broke the piece that holds the socket (1/2 drive).
Not sure what else I can do without destroying something.
I removed the bolts that go through four locking pieces and the large center section (piece that bolts to the tractors hub), should the center just fall out now or is something holding it in?
