A/C - G Trans. gears
BigD701
New User
Transmission locked between reverse and first
while in use. sheared a lot of teeth.
After tear down I noticed we will need all gears for several if not all are missing teeth.
also will need shifter.
Anyone got a good supplier for these.
Thanks. BigD701
Guy"s thanks for the heads up on the part"s.
Took the motor off today and found even more gears with teeth missing. but found I needed brake pad"s too. so it was worth the trouble.
A company in Scottsboro Al. sent me a break down of the whole rear end and trany.
we will go from here.
Thanks again.
