Company Logo (800) 853-2651 Shop Now
WD45 oil pressure
Lavoy
06-08-2010 10:43:36
I put an engine in a guys WD45 for him. Engine is freshly rebuilt, machine shop done, not a hone and ring job. With 30wt oil, new oil pressure gauge, it shows middle or better of the guage when just started. After half an hour on the dyno, I noticed the oil pressure gauge was at the bottom of the normal range. I pulled the gauge and put a master gauge in, 10PSI, engine 180 degrees, on the dyno at 540RPM PTO. I don't have any specs on the WD45, what is normal oil pressure on them. This seems low to me, and more alarming the difference cold to hot.
Thanks,
Lavoy
David Grubb
06-10-2010 12:59:40
 Re: WD45 oil pressure in reply to Lavoy, 06-08-2010 10:43:36
You can shim the oil pressure relief valve spring with some washers.
Tramway Guy
06-09-2010 08:19:15
Also make sure that the 1/4" diameter tube that is pressed into the base is there, it goes up into the filter. Sometimes it comes off with the filter and gets discarded. If it is not there, it will definitely cause low oil pressure.
Lavoy
06-09-2010 13:01:23
 Re: WD45 oil pressure in reply to Tramway Guy, 06-09-2010 08:19:15
Yep, checked that first.
Lavoy
Brian G. NY
06-08-2010 15:13:44
The WD-45 service manual states that normal oil pressure is 12 PSI.
bjb in Tx from Ne
06-08-2010 14:15:57
Are you using the right oil filter. Not sure about WD45, but on the WC and B it is a major issue as well. Search the old forums for lots of info.
Lavoy
06-08-2010 15:26:49
 Re: WD45 oil pressure in reply to bjb in Tx from Ne, 06-08-2010 14:15:57
Not sure, I will check.
Thanks,
Lavoy
Lavoy
06-08-2010 15:39:06
 Re: WD45 oil pressure in reply to Lavoy, 06-08-2010 15:26:49
According to the Hastings filters book, and my local AGCO dealer, the same part number is listed for B, C, CA, WC, WD, and WD45, did I miss something?
Thanks,
Lavoy
Jerry Coulter
06-08-2010 13:47:59
Did you put in new camshaft bushings? That is a key item in a W engine rebuild.
Lavoy
06-08-2010 15:27:19
 Re: WD45 oil pressure in reply to Jerry Coulter, 06-08-2010 13:47:59
Engine is completely rebuilt from top to bottom.
Lavoy
BushogPapa
06-08-2010 20:57:43
 Re: WD45 oil pressure in reply to Lavoy, 06-08-2010 15:27:19
Yes, wrong oil filter on these and you could have NO oil pressure...
Ron..
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 14 80# Massey front weights [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
