Company Logo Shop Now
Need a little advice wd45
electraglider
06-04-2010 03:22:08
I tried putting the engine back in my wd45. I couldn't get it lined up with the shaft that goes in the clutch. I left it partially installed, come back later and the shaft seal is leaking oil. I removed the engine and the leak stopped? I am just wondering if I should replace the seal on the shaft or if it will be OK if I get the thing lined up OK. Probably just wishful thinking on my part?
Herald
06-05-2010 21:49:56
 Re: Need a little advice wd45 in reply to electraglider, 06-04-2010 03:22:08
I thought I saw someplace where they make plastic alignment tools. ( Maybe I dreamed it!!) But they were fairly cheap to buy. Anyone else heard of them? Also I think some are harder to line up as some years don't have a fly wheel hub bushing. At least my WD45 don't. Harold
electraglider
06-05-2010 02:05:33
Thanks guys, yea I need an alignment tool. Not sure how I'll replace the seal though?
JMS/.MN
06-05-2010 09:24:38
 Re: Need a little advice wd45 in reply to electraglider, 06-05-2010 02:05:33
Do you mean the crankshaft seal or the input shaft seal on the transmission? Input shaft- if the engine is out, easy to get to- couple bolts inside the clutch housing to remove retainer, seal should be right there. Some close-by shops may "rent" the alignment shaft if they know you well. Could make one on a lathe- turn shaft on one end to match the pilot bearing bore, rest of shaft would be clutch ID bore.
electraglider
06-05-2010 14:47:05
 Re: Need a little advice wd45 in reply to JMS/.MN, 06-05-2010 09:24:38
Thanks for the advice, yea it is the shaft on the tranny. I haven't dug into it far enough to see the work involved. Sounds like it should be pretty easy, relative to all I been through with this project.
JMS/.MN
06-04-2010 09:20:50
I have aligned some clutches with a machinist rule and eyeballing, but a cutoff input shaft is ideal for alignment. Much easier now, and fits a multitude of AC tractors.
old
06-04-2010 08:53:38
That is a yes, no or maybe thing. Is the seal new?? Can you make it leak by pushing or pulling on the shaft?? Me I would probably replace it unless it is new. As for lining up things did you do a clutch job and not get the clutch disk in like it should be and aligned like it HAS to be.
Today's Featured Article - ... [Read Article]
Latest Ad: Need a grill guard for a 8n ford [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
