wd 45 hydralic oil
I think the manual calls for non-detergent SAE 20 weight.
You can use universal hydraulic fluid instead. I just put a new pump on mine and filled it with John Deere Hy-Gaurd. The pump is pretty forgiving, just so long as the oil doesn't have detergent in it.
i have a wd 45 it seems to be leaking fluid at the clutch throw out lever. i guess i am calling it correctly is this differential fluid or hydralic fluid, it leaks while sitting doesn't have to be running. any additives i can try or how do i replace seal if any??
