AC tractor weights compared
JMS/.MN
Considering buying some tractors to save from scrappers....curious about weight differences between similar models. Model C/CA, 2200/2850 lbs. WC/RC, 3300/4005. WD/WD45, 3388/4465. All are no ballast, except the WD45= shipping weight. Especially note the RC, with the WC frame and C engine, smaller rears, weighs 700 lbs MORE! All info from Dean"s book AC Tractors & Crawlers. Are some castings that much thicker on later versions to allow for the weight difference, along with diff in larger rear wheels, or is the data wrong?
The older tractors, everything was an accessory, so they gave the weight of the base tractor, in some reports, and not, in others. Hydraulic pumps, wheel sizes, pto units, hitch equipment, all can change the weight.
