As I've been fixing up this tractor I notice that the hydraulic engagement plate on this thing doesn't move enough. The slot in the plate is quite long, but it won't move more than about 1/4". Seems to be locked up. Does the tractor have to be running to be able to engage the hydraulic pump? before I took it apart, the linkage was worn and bent so bad that the lever moved all the way, but wouldn't push the plate to engage the pump. How about giving me some pointers on how the pump engagement works. The outer plate that is spring loaded has full travel, but the inner one won't move.
Thanks in advance.
Jeff
Thanks in advance.
Jeff
