new to a d19
harback
Hello I went to look at a d19 today, the owner had never ran tractor, I need some help with the controls.What is the torqe lever on the left and were is the power director, tractor ran good had a few leaks only bad thing was the 3piont went up vary slow? Also clutch didn"t stop the trany all the way,is the clutch wet or dry and is it adjustable? thanks
Short lever on the left side of the torque tube ahead of the gear shift is the PTO engagement lever.
The Power Director is the "Big Stick" lever on the right side with the push button on the top. Forward is high, center is neutral and back is low. That is a wet clutch that runs in trans/hydraulic fluid. It stops the forward motion of the tractor but not the PTO or the hydraulics. Clutch is adjustable inside by moving shim packs between sections. You can access the clutch through the side plate by the lever. Before you do that check that the stop bolt on the high side is adjusted to let it fully engage. Also make sure the set screw on the lever is holding it tight to the shaft.
The foot clutch is a dry clutch on the flywheel just behind the engine. Pressing it will remove power from the PTO & hydraulic pump as well as the transmission. HTH. Mike
