Company Logo Shop Now
WD45 LOADER MOVES-
RUSTIC ACRES
03-21-2010 20:30:23
UP OR DOWN ON ITS OWN, SEEMS NO NEUTRAL AREA ON THE CONTROL LEVER, ANY IDEAS ? , ALSO THE REAR LIFT ARMS ARE PLUMBED TOGETHER.
Tramway Guy
03-22-2010 05:06:39
 Re: WD45 LOADER MOVES- in reply to RUSTIC ACRES, 03-21-2010 20:30:23
You need to make sure the pump is set for 'Hold Position'; according to the decal on the right side of the battery box. There should then be a 'detent' position somewhere in the middle of the quadrant. Buy it is often not precise and will creep a little anyway.
Now, what do you mean 'the rear lift arms are plumbed together'? If you mean together with the loader, this was the standard method of connecting the loader. Often, there was a valve or disconnect coupler in the loader feed line that could be closed so you could operate the rear lift arms while the loader stayed put. But to operate them independently 'on demand' is possible but requires extra plumbing. You are also working with high-pressures here (3500 PSI or so), meaning more expensive valves.
RUSTIC ACRES
03-23-2010 19:10:21
 Re: WD45 LOADER MOVES- in reply to Tramway Guy, 03-22-2010 05:06:39
Thanks for the information ! I plan to divide
the loader and lift arms with a selector valve.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: Shaw due all tractor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
