I got the 3pt we made almost ready to use. All I need to do is change the ends on the links so that they pull from above the lift arms and not from the sides. It should work like it is now, but probably wear out faster?
I hope it will pull this plow ok. I"d like to run it on this tractor but can put it on a bigger one if I really have too. Its a Dearborn 10-181. Plows around here aren"t the easiest thing to find, and not cheaply. Any info on this plow?
It lifts the plow no problem with the large cylinder even at idle. If you stand on the back of the plow it will lift the front of the tractor off the ground. I have 55lb weights for the front rims, 250+ I"m going to mount in the middle of the tractor and may still get all the tires filled with beet juice.
Anyone know how much weight it adds to the rear 11.2x24 tires?
